pinkrobe said:
Frame design is more important than frame material in terms of ride "feel". It 's just as easy to build a noodly Al frame as it is to build a filling-rattler of a steel frame. Tire pressure makes more of a difference to ride feel than frame material, as does the wheel build.
Red bikes are fastest.
While that is absolutely true, the properties of each lends itself to the ride qualities described.
For example, aluminum frames benefit from larger tube diameters due to it's low density / low weight relative to steel. I also believe that higher quality material - Reynolds 853 v. straight gauge 4130 Chromo - makes a big difference.
Years ago, I had a Salsa Ala Carte (steel) and a Schwinn Homegrown (alu.). The ride qualities were completely different. I had the Schwinn, got the Salsa, then went back to the Schwinn. Unfortunately the Salsa was just a bit small for me, so I ended up selling it. Point is, the same wheels and fork were used on both, to sort of 'control' the comparison.
I could ride the Salsa all day; 2 hours on the Schwinn and I was toast. It was super stiff and my back and back side got pounded. It was less of an issue for the few races I did, as it seemed aggressive fast riding meant less time plopped in the saddle.
But, oddly enough, I agree with you more with my experience on my :yikes: road bike. I have had old C'dales and steel frames, and my new(er) CAAD 8 frame rides better than all of them. Also, going to a 25 rear tire from a 23 made a big difference too.
