1 - 20 of 21 Posts
Discussion Starter #1 (Edited)
Magicshine recently contacted me about doing a review of their new Allty1500 and I thought since it and the Allty1000/RN1200 are all similar in setup and only separated by $15 in retail price it would be nice to test them together. Magicshine was nice enough to provide the two Allty's and I already had purchased the RN1200 a while back so here we go.
Daytime Running Light for Urban and Road, Magicshine Allty 1000 DRL
RN 1200 LED bike light. Magicshine 's Fully integrated commuter bike light
ALLTY 1500
SPECIFICATIONS:
.........................................................Allty1500.........................Allty1000............................RN1200
Output (claimed lumens):........................1500...............................1000................................1200
Weight (lighthead/lighthead + mount):..132g/147g........................132g/147g........................165g/180g
Battery capacity:..................................5000mAh.........................4000mAh........................4000mAh
Charging:............................................micro usb.........................micro usb..........................usb C
Mounting system: Adjustable band Garmin compatible (22.2 - 35mm + shaped aero) and Gopro adapter included (helmet mount optional)
Retail Price:..........................................$89.99.............................$84.99...........................$74.99
OUTPUT MEASUREMENTS & BEAM PATTERN:
Output and runtimes for the two highest modes (Allty1500/Allty1000/RN1200)
Chart below reflects only start to stop output levels for each mode. Mode changes can greatly affect runtimes so please refer to updated output charts in post #7 for a more accurate description of runtimes
Very surprised to see how different the output consistency of the Allty1500 was compared to the other two lights. Typical excellent output consistency of other MS lights I've tested just wasn't there. When I contacted MS about this they acknowledged this was normal so while not a characteristic I care for apparently this was done to achieve certain runtime goals. The full just under 1500 lumens is still available when returning to high after any mode change but it degrades from that point similar to initial turn on measurements and shortens runtimes considerably since it increases output levels for around the first half hour following the mode change. The Allty1000 and RN1200 both had great output consistency + out performed their couput claims. Worth noting is that while the RN1200 easily out performed the other two in lumen production its wider beam spread the coverage area enough that the two (same beam pattern) Allty lights had a more intense beam and more throw. Beam spread is still a very good compromise and preferred for steet/path use but for mtb riding I far prefer the floody RN1200's beam for bar use anyway. For helmet use the RN is just too heavy for my liking and with their throw advantage the Allty's are IMO better helmet lights.
User Interface:
Good job MS as far as the mode button operation for all these lights and the program for the RN. Button action is light, positive, and the button is easy to find and use with gloves. Simple low/med/high with flash on a separate program works with the RN for me. Double click to get to the flash mode is not my favorite but with the simple forward light presets I'm fine with it. The UI program on the Allty lights is similar but the fly in the ointment with it is the addition of the DLR mode on the main program. The programs low/med/hi/DLR presets result in going from max output to the 25 lumen DLR mode which equates to just shutting the light off for me. You can't just fast click past it since that will put you in the flash modes so ends up being something I'd rather not have to deal with (PITA for road riding and major problem for mtb riding).The Allty1000 has been around for a yr. now so I'm surprised I've not seen this brought up in any of the reviews.
Mounting System:
All these lights use the same excellent Garmin compatible system. Bar mount and Gopro adapter are included with the light and a helmet mount and a couple of extension bar mounts are available. Supplied strap bar mount will work with any diameter bar + unusual shaped aero road bars. A+ stuff IMO!
CONCLUSION AND BEST USAGE:
RN1200
has a higher maximum output than both Allty's but also shorter runtimes though because of the large 21700 battery it's still very good compared to the sea of 18650 single cell lights out there. The RN is not the best helmet option for me because of its weight and bar oriented beam pattern. It is a very nice/easy to use/powerful mtb bar light and still functions well on the road and paths. It's also the least amount of money and IMO the best bargain.
Allty1000 is my favorite for road and path use. It has very good runtimes and in some situations even out performs the 1500 version for slightly less money. It also work great as a helmet light and has better output consistency than the 1500 version. Easy to see why the Allty1000 has received such great reviews, other than having to scroll through the DLR mode in the main program I can find nothing else to complain about!
Allty1500 is the best helmet light because it has the most throw and is light enough not to be noticed. It may also be your best bar option for road/path if your riding habits regularly require its extra output and beam distance. If you don't need the extra umph it still shares all the nice features of the 1000 with some nice performance advantages if you don't mind paying closer attention to how you use the light to extract its best performance (whether your looking for higher output or longer runtimes).
RN1500 is technically not marketed in the US but available through ebay/Aliexpress and co-branded by Olight as one of their bicycle specific lights. The RN1500 is quite the powerhouse recording over 2000 lumens at startup and maintaining a pretty high level for the first hour or so IF you don't mind cycling through the modes every once in a while to keep the output at its highest levels. As with the 1200 this is a wonderful bar flood and a bargain too.
Mole
Seeing that you said you prefer the Allty 1000 ( for helmet use ) I was wondering how you think it compares to the Ceco 1000 that both you and me both own ( both for helmet use and bar use ).
Discussion Starter #3
I've tested so many lights lately it would be hard to say without taking them both out for a side by side. Will get back with an answer for you in the next couple of days.
Mole
Discussion Starter #4
OK Cat, my answer for which is a better helmet light is going to have to be a blend of ride testing and output measurements. I only was able to get about 20 min. of trail riding with each light (paired with the RN1200 on the bars). Initially the Ceco had a clear advantage in intensity and throw but that advantage had definitely degraded a bit at the end of the 20 min. From that point I'm going to have to speculate using some measured output data for both lumens and max lux I did on both lights last night. The Ceco has about a 25% max lux advantage initially that fades to about 10% (barely noticeable) by the 45 min. point but fades fairly quickly after that where as the Allty starts out a bit lower but remains strong till about 1:45. So for general trail riding (for faster more open trails I'd be looking for a more powerful light than either of these) as a helmet light which one works better largely depends on your runtime requirements. For any type of bar use the Allty would clearly be my choice. Better beam, more lumens (except at startup), much better mounts, much longer runtimes, much more user friendly.
Mole
Discussion Starter #5
I did a longer lights on ride (43 mi.) with the Allty 1500 last night and experienced a couple of things I consider worth noting. Using low and med modes (mostly med) and switching intensity levels occasionally the charge cycle of the 1500 only lasted for 40 mi. If you look at the output chart I posted you'll notice the med mode is significantly more powerful for the first 30 min. and then dips down to output levels similar to the 1000 (which is fine for most situations). Switching modes restarts the output cycle and while it's nice having a brighter light it also requires more current from the battery which resulted in the much shorter than expected runtime I experienced on last nights ride. So since longer runtimes is the main reason for choosing the 1500 oveer the 1000 unless you need those extra 300ish lumens it's best to just leave the light in med and not try to use low to conserve some battery life cause that may end up giving you just the opposite effect. Secondly I did find that the extra claimed 100 lumens the 1500's low mode generates makes it far more usable than the 1000's low mode which just isn't quite enough light for me. Hope this helps potential owners of the Allty 1500 figure out the best way to use their lights without having to learn the hard way.
Mole
Discussion Starter #6
Allty 1500 specificaation and performance update
I had always assumed the Allty 1500 shared the same XP-L emitter with the 1000 version but apparently that's not correct (according to the Magicshineusa website). The website lists the 1500's emitter as a SST40. This doesn't change the output consistency or lumen output numbers but after retesting this morning did reveal a more favorable max lux to lumen ratio for the SST40 light and supports the idea that if used correctly the Allty 1500 may be a better performing helmet light. If you look at the output chart in post #1 you'll see that the 1500 has a lumen output better or equal to the 1000 but because its SST40 emitters produce about 20% more max lux per lumen the 1500 maintains a throw advantage for approx. the first 30 minutes. After that its lumen ouput dips enough below the 1000's to lose its advantage but simply scrolling through the modes from high back to high will return it back to its original output and another 30 min. of throw advantage. Of course this will also shorten the runtime since you'll keeping the light at higher output levels but does allow you to choose depending on your ride priorities. I'd still have preferred the Allty 1500 had the excellent output consistency of the 1000 or RN1200 but I'm picky and spoiled and have to remind myself that consistent output is the exception and not the norm for single cell/emitter all in one lights.
Mole
Discussion Starter #7
OUTPUT & RUNTIMES + RN1500
I'm still very happy with the performance and operation characteristics of the RN1200 and Allty1000 and while I still wish the Allty1500 and newly acquired RN1500 operated just like their less powerful siblings I have learned a few things about their performance in regards to how they are used that are important to point out. After more usage of the Allty1500/RN1500 my ride experiences were just not matching what I'd seen when doing my light-meter readings and further testing revealed frequency of mode changes made a considerable difference in output levels and also in runtimes. Unlike the RN1200/Allty1000 the two 1500's output degrades a considerable amount initially but just switching through the modes returns them to near startup levels which is good when you need the extra power. With each mode change the output increase affects these lights for about the next .5 hrs. to varying degrees and the increased current draw to make the extra output can shorten the modes runtime by a couiple of hours in some cases which could easily leave you in the dark since the low battey level warniing lights don't give you any warning till there's only 20% of capacity left. I made up some new output charts to better reflect this characteristic and you still can achieve the longer runtimes posted in the OP but only if you run the light start to finish in one mode with no changes (mode level/on/off). I do think it's nice to be able to tap into the extra output when needed but think maybe a more traditional "boost mode" setup where you choose when to go bact to lower output levels and conserve battery energy would be much simpler to deal with.
This a good example of excellent high/med mode output curves for a single cell self-contained light. Brightness and runtimes in use matched this model very closely.
Jagged lines indicate mode changes. Easy to see it increases output levels but also considerably decreases overall runtime. Regulating the output curves to be similar in nature to the RN1200/Allty1000 would still give you the shorter runtimes in spite of the larger battery capacity but adding a additional mode between med and high would allow highest output access without killing runtimes.
Similar results to the Allty1500 but a bit more exaggerated because of the RN1500's power advantage (?). Shorter shallower dips represent 15 min. between mode changes and the longer deeper dips are @ 30 min. Interesting changing modes only smoothed out the degree of high mode degrading and didn't return the light tho higher levels. Same overall result in shorter runtimes.
Hopefull this will help owners of the 1500's better understand what their light is doing and how to best use them.
Mole
I managed to pick RN1500 on Ali for £35,
A few questions if you don't mind,
If you were to switch to a lower power setting then back to medium straight a way would that help maintain the medium setting at a higher lumen count or would that still cause it to drop back to just over 500? without it shooting high up to 1200 like show on the graph thus draining the battery? or would it be better to leave it in medium? My normal rides at night are 2 to 3 hours
How useable is the 500 for general tail riding nothing to gnarly? it I just left it on medium for my ride duration.
Tom
Discussion Starter #9
After any mode change output will return to near startup levels in whatever mode you go to at least till the battery drops to a certain voltage level. Using my test results as an example you would get 3 hrs. of med mode runtime with a similar number of mode changes(5) but more than that might shorten the runtime below what you need to cover your longest rides. Certainly possible to ride easier trails with 500 lumens so leaving the light in the med mode would be safer but keeping your mode changes to a minimum you still should be able to use the higher levels when you need it.
Mole
What do you think of the RN 400, and where it might fit in as a helmet light?
I realize it's a lot less in power & battery rating compared to the others, but it is much lighter than the RN 1500 (which I have a few of for our bikes). I currently have a Garmin quarter-turn mount screwed into the top of my helmet, so I could snap in either the RN 400 or the RN 1500. I picked up a few helmet brackets that Magicshine sells for the RN 400, but don't like it since it's not as secure as the screwed in bracket, and it sits way too high on the helmet and throws off the balance with the weight being further out from your head.
Discussion Starter #11
Easy/simple to operate, fairly wide low intensity beam should make the RN400 a great neighborhood/path bar light. The 85g RN400 might even work well as a helmet light when paired with another RN400 on the bars but most likely its 400 lumen output would just get absorbed into the beam of the 1500 providing little if any forward illumination benefits. It would still make you more recognizable to other traffic and provide an inprovement when looking around corners if that;s all your looking for.
Mole
How exactly does the USB C power delivery work (there are a billion standards!).
Will the RN lights charge from a battery pack while running?
Can charge my GPS while running. The RN400 would make an excellent emergency light and power backup.
Discussion Starter #14
I guess at this point I don't really know for sure. When I first got my RN1200 I asked my Magicshine marketing contact about this and was told they didn't recommend charging while in operation because of posssible battery damage. Since then in the Sweet Cyclist review of the same light it is listed as a Magicshine supported feature. I guess it's time to contact MS for clarification.
Mole
Mole
I'll let you know when my RN900 arrives!
Discussion Starter #16
Looking forward to hearing how it works. I've hooked my 1200 up to a powerbank and that seems to work fine but I don't have a C to C cable so I cant test if it will charge something else. Would the RN400's small battery capacity be that helpful for charging another device? I like these RN/Allty lights quite a bit but will be nice to get another opinion.
Mole
Discussion Starter #18
Decided on the 900 though for the extra capacity and useful runtime.
Sounds great and I think you'll end up a lot happier with the higher output/larger battery capacity 900. I'm 2 weeks into the recovery of my shoulder so guessing another 4 weeks or so off the bike so hopefully you'll have your light before I get a chance to ride with mine.
Mole
Discussion Starter #19
I got a response from my MS contact regarding usb charging while in operation. The reply was a little vague (Chinglish) but basically no complaints or warnings not to do so. I also asked about differences betweeen the RN900 and Allty800 and was told different model and 100 lumen claimed (measured) output difference. More details would have been nice but at this point I'm guessing the RN900 is a harder driven Allty800 which would make sense considering the shorter mode runtimes of the 900.
Mole
1 - 20 of 21 Posts
