As above, weight and bits you’ve built it with would be good! Cheers.
It's a 2018 SBG. Biggest thing I'd say to bear in mind if building frame-up is the insert length on the alloy frames is fairly short. Don't plan on running a 170mm post on a medium frame unless you have freakishly long legs.Cheers Andeh, just the sort of of info I was after, even better cos I'll be after a medium frame myself. BTW is yours an original Smuggler frame or SBG type?
