Conventional aluminum foil will crush very quickly. I had an old MRP swinglink from a travel kit for an old Spec Enduro that had a switchable "chip" that you moved 180 degrees to change travel. It had a tiny bit of slop in it, so I tried a bit of good aluminum foil wrapped in a layered manner on this chip. It didn't last a 10 mile ride before the slop was evident again. Foil is too soft IMO to be effective in these types of applications. There are probably some situations where foil could be effective, but at key suspension component locations is probably not one of them.
Did your bike's shock use two-piece "top hat" style spacers or a thru-axle style? I strongly recomment the thru-axle style. They promote longer bushing life for obvious reasons.
