What do you think?
  • The anodized brake levers do not match the hubs, you can’t post here
    Votes: 1 3.7%
  • It needs a gravity dropper and a carbon fiber lizard skin chainslap protector
    Votes: 1 3.7%
  • I have four monkeys with the ebola virus locked in the trunk of my car
    Votes: 11 40.7%
  • You should get some carbon fiber stickers to cover the coil spring
    Votes: 3 11.1%
  • The worst four years of my life were sixth grade
    Votes: 0 0.0%
  • Single pivot non dw link frames suck
    Votes: 2 7.4%
  • My cat’s breath smells like cat food
    Votes: 3 11.1%
  • BRING TEH PAIN!!!!!!
    Votes: 6 22.2%
1 - 20 of 29 Posts
Banned
Discussion Starter #1
Ok check it out, my ALL MOUNTAIN DHR. As you might notice, I switched to a 160 rear rotor to save some weight. I am using a Gustav on the back end for ultimate skidding power. It is kind of heavy but worth it. I was riding a 5 spot but it wasn’t all-mountain enough so I got this instead. What do you think? Oh yeah, do you know if anyone makes a front derailleur that will fit this frame? Should I get top or bottom pull?
Frame: 06 DHR Medium
Fork: Rockshox Domain 318 180mm
Rubber: Maxxis DH (good for skids)
Wheelbase: 45.75
BB height : 14.5
Weight: 34.23 pounds
Committed
Gotta ditch the Saints, some carbon road cranks would be sick!
In addition forget the front derailleur and go SS, way more core.
Lay off the Levers
Dude WTF is WRONG with you??? Don't you know Avalanche makes a remote shock?
"I have four monkeys with the ebola virus locked in the trunk of my car"
Thanks for the new signature!
a tight kick sound
No front brake at all bra!
Plus those heavy arse tires are not needed for AM riding :)
Ohhh ohhh and a GRavity retarder seat post is def the way to go (u know my vote).
Would help you get it up there high enough for those long climbs!!
Plus...is that rear der a sora or something? Pfffshhhh, don't those only come on road bikes?
Any real DHer knows that road parts will immediately combust on contact when used on a real DH trail.
Nice :)
Now with flavor!!
You're going to need an all mountain camelback.
Accept no substitute.
I think it looks sweet.
When it comes time to upgrade my 04 DHR to the new model i will be turning the old frame into a 5 inch front and rear bike. Put a shorter shock on and it will rip for sure.
Time flies...
Man, I read the poll choices and thought it was Friday already....
:p
Rides like wrecking ball
rmac said:
Reminds me of Rene's 'xc' Dare of yesteryear... :D
I had an old-school '99/'00 Dare XC. It was the coolest bike ever built from wet noodles! :yikes:
involuntary dismounter
ebola monkeys all the way!!!
Banned
Discussion Starter #17
Ok, seriously now, I've just never seen a DHR with a single crown so thought I'd give it a try and post a pic in case anyone was interested in seeing how it looks. Pretty sure the Totem and Domain have the same axle to crown. I am running the same headset configuration on both of my bikes, using an E13 reducer on top, and I split up an FSA extreme something-or-other for the bottom half, so it was really easy to swap forks. The lower headset cup on the DHR is actually upside down. The bearings are the same on that headset top and bottom, so I ordered an extra crown race... it works. I like the low stack height of the E13 cups on top, and the larger bearing size (and increased head angle slacktitude due to height) of the FSA on the lower race.
It's kind of weird sitting on the DHR with a single crown, as I am used to seeing a 888 up front. Something about having the big triple just makes the whole setup feel invincible IMO.
P.S. Oh yeah, it ain't anywhere near 34 pounds!
Bite Me.
That would be hot with a 650B wheel up front.
Outcast
When this frame was built up in dh mode, I had a 24 inch wheel in the rear for a while, so I could run bigger rubber. A 650B up front and a 24 in the back would have been mega-hawt!
1 - 20 of 29 Posts
