I've read the online tech manual about aligning the replaceable dropout on Hecker.
http://www.santacruzbicycles.com/tech/heckler_tech.pdf
Generally it's always nice to have adjustment options on things, but isn't this something that should simply be "aligned" when the mounting bolts are secured (without any adjustments), to be dummy-proof? I mean, you just secure a regular/conventional replaceable derailleur hanger, and there's no options to adjust with it. (And it's supposed to be "aligned", as is, right?)
I'm just afraid that I may mess up something by not evenly micro-aligning it 100% straight, which may lead to uneven stressing of rear axle (upon landing), or who knows what else, in a long term...?
Did I miss something here, or am I just being over-paranoid?
Finally, as for "Step 3" in this online tech manual, you're suppose to do this step #3 with a rear wheel & derailluer already installed from step #2 (even though the picture of step #3 shows no wheel or derailleur installed with it), correct? Or, do you have to have the wheel & derailluer off, when turning the adjustment screws?
Thanks for the info in advance,
- PiroChu
- PiroChu
