Thanks! Would THIS one work on a Shimano XT M760 11-32t?eurorider said:This is what I do. With an Al lockring, the XT is only about 10 g heavier than an XTR and XT cassettes cost half of what XTR goes for.
The lockring doesn't have to be XTR or Dura-Ace. There's also SRP and other brands. SRAM road cassettes are cheap and already come with a Al lockring.
I would check with them if it's for a 11t cog or 12t but I thought Token lockrings were Al and the stated weight of 12 g is the kind of weight you would find in a steel lockring. Al lockrings are about 4-5 g.dulyebr said:Thanks! Would THIS one work on a Shimano XT M760 11-32t?
Would you happen to know the weight?Strong Ti said:for 11T cog. I'll see if I can post a pic soon.
Not with the 34t model. 240g for the XTR, 290g for the XT.eurorider said:This is what I do. With an Al lockring, the XT is only about 10 g heavier than an XTR and XT cassettes cost half of what XTR goes for.
Yea, there's more incentive to use the XTR when you're running the 34t cassette. If I was running 2x9 or 1x9 I'd definitely be using a 12-34 cassette and then the XTR would make more sense. But I run the XT 11-32 because I think my area warrants a triple setup.Hecubus said:Not with the 34t model. 240g for the XTR, 290g for the XT.
Hey DIRT BOY,DIRT BOY said:4-5g.
Drats!DIRT BOY said:11T only and CAMPAG RED only
