1 - 2 of 2 Posts
Found my drive side bearing cup migrating out about a 1/4 inch. Anyone else have this issue? Will Loctite fix the problem? Per Niner encyclopedia it's supposed to be pressed in dry, which I did.
Sent from my LG-LS980 using Tapatalk
If it's coming out then it was setup incorrectly. Simple as that. The crank set shouldn't have any extra space that allows it to come out. You may need to add some of the extra clear spacers that comes with most pf30 cranks
1 - 2 of 2 Posts
