Hi all,
Question regarding pressure loss on a Stumpjumper Evo’s DPX2 shock.
First a disclaimer, I know how to set shock pressure, equalizing the two chambers before setting and reading the final pressure.
My previous bike had a different leverage ratio and the RS Deluxe only required 160PSI to achieve 30% sag. It was pretty much set and forget, I took several weeks before I needed to touch up air pressure.
I noticed that I get a lot more pressure drop on the Evo’s DPX2. My baseline pressure for 30% sag is 260PSI. I did the following measurements:
26/06 – 260PSI
02/07 – 240PSI
That’s 20PSI in 6 days, 3,3PSI per day.
Is this normal??
26/06 – 260PSI
02/07 – 240PSI
Is this normal??
