Sounds like you've got it - 120# is a good starting point. Also be sure to adjust the rebound to get the rear end to track smoothly. Try a tire pressure of about 5# less than your 26-er. Before riding hard I suggest that you remove the rubber and throw these Bontrager Race wheels on a truing stand to check spoke tension, as mine were loose and the rear uneven. (A 29er with fat rubber will not fit on a Park TS-2). Before re-mounting the tires separate the tubes and add talc to prevent snakebites. Best of luck in your race!
