1 - 3 of 3 Posts
my fox vanila r is making weird sounds when i compres it it sounds like some one is chewing gum realy loudly also the threads that you adjust the spring with are locked up so i cant turn it at all any advise would be great thanks in advance
spray some lube on the threads...
wait a bit and get a channel-lock type whrench around the spring collar if you have to. counterclockwise turns, a bit at a time, and it should loosen up. don't preload the spring so much...you may need a heavier spring for your wieght. as for the chewing gum sound...??? service time, friend. send it in before you blow it a whistler.
Discussion Starter · #3 ·
ugg if its not one thing
i finaly got the spring to turn and as soon as i bounce around a bit oil starts leaking out the rebound knob
on a unrelated topic anyone wana buy a fox vanila r theres nothing wrong with it i swear :D
1 - 3 of 3 Posts
