1 - 6 of 6 Posts
Hi,
I'm thinking about getting Poploc Adj. remote control to my 2008/9 pike 454 Air U-Turn, This:
Product Machine Black Gadget Grey
My question is what parts I need to get?
My pike is equipped whit motion control:
Red Fender Logo Carmine Bicycle accessory
Do I need to change the Full kit as show in the pitcher?:
Product Red Line Technology Circle
Or I can get parts: 7, 8, only?
White Line Drawing Circle Illustration
Thanks In advanced for your help
Discussion Starter · #3 · (Edited)
Super Moderator
from it a distance (like in the diagram) it looks the same as the one without spring (part 13 from your diagram), but it has a spring inside that makes it return to open position.
(13) 11.4015.316.010 Compression Damper Motion Control External Gate Remote Adjust-Reba Revelation (09-10)
Discussion Starter · #5 ·
I got it now.. thanks :thumbsup:
in order to assemble this kit, is it enough to remove the top side of fork and then exchange the kit Or one needs to relay take the fork apart..?
thanks
Super Moderator
thanks
no need to tear it all down...just exchange the compression units.
though if you haven't changed the oil in a while, you could take advantage and do it at the same time :thumbsup:
1 - 6 of 6 Posts
