I woudln't
appleSSeed said:
I'm building up a cool little city bike for my roommate and I just got a set of premade Bontrager wheels. They have a blueish/grey anodizing that I want to take off via oven cleaner. What do you guys think? They are disc wheels so I'm not so worried about the rim strength after (and since I won't leave it on very long) mostly concerned about the nipples and being able to true the wheels afterwards..like if the nipples corrode or whatever. Thanks in advance.
... unless you disassemble them... and if they don't have brass eyelets. EZ-Off will probably do crazy things to brass.
That said, I've done a lot of EZ-Off silver parts in my time, and it works out great. It just etches off the top thousandth of a mm, then you polish that away. You will have to re-polish them from time to time as the aluminum oxidizes. Aluminum oxidizes in a way that it seals itself, unlike iron or steel rust which just keeps on going until the metal is gone.
Use Simichrome or other metal polish that leaves a protective coating when you are done, and the silver finish stays bright for a while. You'll have to buff it up from time to time.
I did my H-Bars and stem in EZ-Off silver, as well as a bunch of other parts.
Oh yeah, I did my seatpost too!
