I'm doing a drivetrain upgrade on my '03 S-Works Epic. Some older parts started to go, and I would like some advice from shop/pro wrenches on whether it is worth doing the job myself, or taking it to my local mechanic...
My front XT der developed ton of play recently and a prodigous rattle. Meanwhile my rear (right) XT rapidfire shifter doesn't always engage when I use the thumb lever (probably some worn out internals), and I've been nursing it along for a year or so waiting till it completely failed. Now, the combo of the two problems is too aggravating to make it thru another 24hr race. Add to that that my rear XTR der is 5 yrs old, and I want to upgrade to rapid rise shifting pattern to help climbing...
So I have a new XT M761 front der, a new XTR M960 SGS rear der, and a pair of new XTR SL-M952 shifters + cables sitting at home.
I'm a relatively competent home/trail mechanic (I use a torque wrench, clean everything religiously, fix brakes, true wheels, etc) but I usually try to avoid adjusting my deraileurs. I've also heard from several sources that the drive train on the Epic can be tempermental to adjust... Should I take a swing at trying to set up the new rapid rise myself -- or should I just drop the bike off at the shop????
