1 - 10 of 10 Posts
Hello All,
Thank you for taking the time to read my post.. ;)
I was at a swap sale and "Acquired" a K2 Sidewinder 6k series full suspension *Snicker* mountain bicycle for next to nothing. From what I have read so far people have been beating up on the components, like the rear shock and the ability of the fr/rr disc brake system.
First off how would I size out a new shock for the rear of a bike? Then two, how would I go about sizing out a new disc brake system?
One more thing I need to think about is that there are new specialized rims on the bike and I dont see a disc on the front rim. Will I be able to add on a disc to the front rim? Or do I need a new rim all together. If possible Id like to do some off road and regular street riding on this bike for the next year or two when I will pick up a new frame and a fork.
Thank you for your time and patience...
Don't put a lot of money into that bike,just ride it. A shock could cost over 200$ ,brakes from 70$ and up. Rims have almost nothing to do with being being able to run disc's ,the hub is where the rotor mounts. You also need a mount on the fork for the caliper.To size a shock you need to measure the distance between the eyelets with the shock compressed and know the amount of shock travel. Do you know what year the bike is?
Discussion Starter · #3 ·
Thankx for answering back.
No idea about the year but if needed I can post some pics. The original setup of the bike had disc brakes. But the whole setup is missing from the front. Caliper, disc, and no cable. There is a place to mount the caliper thou.
The name on the bike is
K2 Sidewinder DS 6000 series. Im sure that wont help..
To go back to the front disc ,you would need a wheel ,rotor, caliper and cable. You could get a wheel for under 100$ and a Avid bb7 front brake for under 50$ . It looks like the lever is still there ,hard to tell from the pics. Do a search on ebay or amazon for parts.
Discussion Starter · #8 ·
Yes the lever is there and the fork ha the place to screw the caliper onto the fork. Im guessing having a different front brake wouldn't matter? Or should I get front and back?
Any help on the rear frame shock would be helpful. I'm aware I need to get the correct size before I can do anything. But can someone recommend a brand and type. I hop on the bike now and its drops significantly. Im 6' 2" and 210lbs.
Thank you,
Discussion Starter · #9 ·
Im looking to pickup the front new caliper? Do I want the 160 mm ones? Do you think it would be beneficial to buy the rear one also?
You need a wheel with a hub that will accept a bolt-on rotor.
160mm is most often used with that type of bike.
I would get an HS1 off ebay for $11 or so.
Forget the existing lever.
Get a complete Deore M615 or SLX front brake right side. It's assembled, prebled and can bolt right on to a fork with the correct mount, or may need an adapter.
The rear would be a bonus but it not as important.
Ribble has the SLX set, moto style, 122. Jenson will price match US style.
Ribble is out of stock on Deore at 96.
1 - 10 of 10 Posts
