1 - 3 of 3 Posts
· Registered
I am contemplating of buying the kurt kinetic trainer? I don't know if it is durable compare to 1upUSA. I know that it is fluid trainer. I heard cyclops trainer has tendency to leak fluid when the rubber ring wears out. I am not sure if the kurt kinetic will have this similar problem.
I need advice from veteran riders whom had used the kurt trainer in the past.
· Registered
The Kurt Kinetic trainers don't leak and are a completely different design than the Cyclops that have had problems. I have around 300 hours on my Road Machine and it's working flawlessly.
From everything I've heard about the 1Up, you really can't go wrong with either one.
1 - 3 of 3 Posts
