1 - 7 of 7 Posts
Hi MTBR,
This is my first post on this site, but I often refer to these forums for tips/advice.
I am currently riding a hardtail with a 2x9 setup and a bash guard in leu of a third chainring. I want to change to a 1x9 and ditch the front derailleur. I would like to do this without spending too much (under 100$). Looking for any product recommendations (I am considering an MRP 1x chain guide). Also wondering if it is possible to keep my bash guard with a chain guide, or if I will have to ditch that too. Any advice would be greatly appreciated.
NedwannaB
Hi MTBR,
What bike, crank set and derailleur you are running would get you a little further with suggestions.
Since you don't have a clutch type derailleur, if you can get one of the narrow/wide drop stop rings from Race Face (~$45) and a C-Guide dangler (~same $) on your setup you should be able to drop the granny ring and keep your current bash ring without getting the MRP top guide. Shorten up your chain by wrapping it around big cassette cog and front ring (w/out running it thru the rr derailleur) plus 2 links and you should be good to go.
Discussion Starter · #4 ·
I am riding a 2012 Fuji Nevada 2.0. Crankset is a Shimano Alivio 22/32t (44t ring has been replaced by Salsa bashguard), the front derailleur is a Shimano Alivio, 34.9 mm, rear derailleur is a Shimano Deore SGS, top-normal 9-speed.
I checked out the chain dangler. Does that essentially serve the same function as a chain guide?
Thanks JMac
Discussion Starter · #5 ·
The raceface NW ring seems like a pretty good way to go. The reviews say you can run it without any sort of guide, even on a hardtail. Looks like it would work with my bashguard as well. Definitely considering this option.
Thanks Slash
1 - 7 of 7 Posts
