Well my tora 302 started leaking oil in the bottom and little at the top,on the right leg(yeah i know, rebound damper).so i will need a new fork, im set on tora(maybe recon if you can persuade me) but im in dilemma which one? solo air or u-turn.im 210lbs and i need reliability,less maintenance as possible and to be able to cope with my weight. and should i try to find 2010 forks(are there any differences from last year)? and my front hub(fireeye excelerant 520) has option to be converted to thru axle 20mm..
