What are the advantages of a direct mount stem?
im sure it will all depend on how it hits.Quarashi said:Out of curiosity: Take a bike with a direct mount stem, put it through a really bad handle bar wrenching crash. Which would *probably* give in the first, the fork (stanchions), the frame, the stem/crown interface or the bars? With a normal stem I would assume you would just lose alignment.
My buddy's 888 direct mount stem sheared off at the bolts when he wrecked bars-first into a tree. As has been said before, it depends on how you hit.Quarashi said:Out of curiosity: Take a bike with a direct mount stem, put it through a really bad handle bar wrenching crash. Which would *probably* give in the first, the fork (stanchions), the frame, the stem/crown interface or the bars? With a normal stem I would assume you would just lose alignment.
I did that. I tried to bend the handlebar with my leg during a crash...but ended up twisting my knee causing a tibial plateau fracture instead. The fork (2010 Boxer) was actually twisted out of alignment, but I only had to loosen the crowns and re-align them with the lowers to get it all back in shape again. Sadly, the knee took a bit longer...Quarashi said:Out of curiosity: Take a bike with a direct mount stem, put it through a really bad handle bar wrenching crash. Which would *probably* give in the first, the fork (stanchions), the frame, the stem/crown interface or the bars? With a normal stem I would assume you would just lose alignment.
agreeboogenman said:-lower
-direct contact is better than being clamped to a tube(stiffer)
