I have the XC model and am having the same trouble with my front brake. On mine, it looks like the inside piston isn't retracting all the way. I posted a similar thread a week ago and I was told to keep pushing the piston back and forth untill it works free and retracts, or spray windex into the piston. I didn't try the windex trick, but I am not sure if it is a good thing to do since all I have read about brakes tells you to only use alcohol and alcohol only. I plan on doing a good cleaning with alcohol before this weekend ride and see if working the pistons back and forth does anything.pcrap said:
Let me know if you find a solution. Right now, I have a little drag, but I can ride with it. By the way, do you also have to use the Mounting Adapters for IS mounts?
