Has anybody gone to the dark side and added a front derailleur?
I have a crankset that will allow me to swap dual rings back on. I have a frame that accepts direct mount and side swing/front pull derailleurs. You can get XTR level front shifters and derailleurs for 80% off.
Would you ever put one back on?
I ask because I miss my front derailleur (a little). I never found them that hard to tune, and being able to drop the equivalent of four gears at the rear was awesome living out here in new england where the terrain goes up and down, rather than gradual shifts in grade. Plus, with a smaller ring you get an increase in antisquat, which can help you climb steep grades (IMO/experience it does), then you can shift back up at the top and lower pedal feedback/antisquat for the ride down. I'd be running a 10-42, and do not need additional range, but want a big change in gear ratio with a single shift.
What do you think?
What do you think?
