adapters from 180 to 203
2857 Views 5 Replies 4 Participants Last post by  outback82
Hi all, i replaced sram brakes and disks 180mm with shimano xt with 203mm rotors. I have one og this SM-MA-F203P/PM Adapter for Front 203mm
Do i have to buy the same model for installing the rear caliper or is there a spefic model for rear?
1 - 6 of 6 Posts
It depends what the current mount and adapter are at the rear of your bike.
That one you linked is for 180mm PM to 203MM PM.
i have no adapters anche i have post mount.i installed that adapter on the front. just wondering if i have to buy the same
If you have a 180mm rotor without an adapter and you want to increase the the rotor size to 203mm, that is the adapter you need to use, it can be used on front and rear post mounts.
  • Like
Reactions: 1
1 - 6 of 6 Posts
