Rebuilding helps!
When I had Claws I would repack all of the from the start and it helps tons. You can even do it without removing it from the hub. Just be prepared for a lot of bearings to come out and COUNT the bearings so you know how many need to go on each side (The number isn't the same for front and back, I wish I could remember exacty how many but it's fourty something.) You can also remove some micro thin washers to remove some play in the freewheel. To grease the bearings and pawls I use Park Poly lube cut with Phil Tenacious oil. You don't want to use too thick a grease or the pawls will stick and get that "Freewheel in both directions" Zen dicotomy thingy. This will also quite up your freewheel quite a bit. To remove and tighten the lockring on the freewheel I'd use a small pointed punch and a hammer. The two holes in the lockring are for a BB tool but I've found the hammer and punch to be easier and quicker to apply force/torque. It's reverse thread so righty=loosey. When you get the lockring off you'll see the washers that sit directly under it. These are how you adjust play in the freewheel. It's a process of removing a single one, tighten the lockring down, check the freewheel and make sure it's adjusted ok (i.e no play, or no binding) and if it's not right start over. Second you probably notice a lot of tiny bearings. This is when your gonna want to start counting. Next a magnet is super useful in getting the bearings out neatly. If you want to know more let me know....this is getting way long and probably boring.
