1 - 10 of 10 Posts
· Registered
Thanks to Acme Bicycles, I added was able to add a few more things to my Coiler build at an unbelievable price! Check it out:
E13 DRS Chain Guide: used $40
Deemax Front Wheel: used $75
Gravity Dropper Seat Post: $FREE.99! Im workin it off, trail work, etc.
Again Acme Bicycles Rawks! "Thanks Tim/Sparrow" Buy at Acme everyone!
· Registered
Discussion Starter · #7 ·
konut said:
hows the drs is it good.
you like living dangerousley dont you hucking 8 footers on xc cranks,could you not get some cheap hone saint maybe.
i also read your write up about your forks,could you not just fit coil springs to your forks.
The DRS works great, and I have no complaints what so ever. I have yet to drop a chain. It simply does its job...
In regards to the cranks...I dont really have much of a choice. I had to use those cranks because they were the only ones that I had that would work with the DRS. I have ONLY enough cash to send my fork in, so yeah....being poor sucks:mad: Any donations will be readily accepted, just ship em off to Rapid City!:p
I probly could figure out a way to get coils put into my 66, but that would mean I'd have to get rid of the Doppio Cartridge. Both the NEG air and PAR I use, and like. M-Hill here in town "which i ride frequently" has a very steep climb, and if i dont suck the travel down a bit, my front end is very hard to control. I also like the feel that the 5-10 psi PAR gives to the stroke. Other than that I keep it at the full 170mm. I have also found that if I go about frankenforking things, it tends to create more then solve problems. So, I think I will just stick with my 66 as is, and have it serviced. Please let it be warrientied o great Marzocchi gods!:aureola: I do however see a coil fork on my bike in the mere future:thumbsup:
· Registered
Discussion Starter · #9 ·
konut said:
sorry dude you got me wrong.
the 66sl and 66rc2x use the same forks just different innards so im just thinking could you not put the guts out of an 66rc2x into your fork.
how long your stem by the way.
and yes being poor does suck my bike wont be ready till may or even june
Yeah, i could use the guts of an RC2X.... Do you have an X Cartridge that ur itching to get rid of? My steerer is 7.5 inches...
1 - 10 of 10 Posts
