1 - 15 of 15 Posts
Yeah, I think on the back of the customs that have been made, I think there are four I know of now.
68 is very much an all mountain head angle which I would say is appropriate to an all-round 140mm 29er. Its a bit more wandery on climbs than the standard bike, but still fine, similarly in tight stuff, it requires more body english particularly to change direction.
I don't now whether they'll keep the BB area like mine/Cyril's (AFR stylee) or tidy it up and maybe lighten an Ion style one, we will have to wait and see..
but they had the geometry and design so "spot on".:D
strange they went from a spot on 72 degrees to 68. what could they be thinking?!?:rolleyes:
The geo is spot on for a 120mm xc bike(remember this is an AC not an AM 29er). The 'new' model speculated above is a different animal. 140+ rear and slacker. To my knowledge 68deg is not a given but would be a good guess.
I have both the old and new. I'd still take the old for all day epics as it builds lighter and is a grea bike in its own right. The new model with the 140 fork is a bit heavier and while it'll do all dayers with ease it's a more hardcore tool than the original.
Horses for courses. Not everyone needs/wants 140mm and 68deg ha's from their 29er.
just taking the pi$$ out of the op. ;)
Ha, and I was about to chime in, given I've also used both and own one.
I'd have no quibbles at all about using the std AC for XC duties and pretty much any descent in the UK bar a DH track.
Mine is a different animal, requires riding in a different way, I personally prefer that, but that's me. I'm really rather liking the 66.9deg mine is at at the moment but its not as good an all rounder as when it I had it steeper.
I'll probably put it back to 68 for most of the time with the 140's on it
your's has custom geometry then?
Yes, very much so, I changed almost everything. Mine is very similar to Cyril's, actually not quite as slack inherently but I wanted mine for everything from 50-60mile per day multi-day races (Lightweight 120mm fork, 120mm rear travel) to Enduro racing in Italy (Fox 34 140mm fork, 147mm rear travel) so it is designed around both 120 and 140 forks and to have an angleset as I wasn't sure what head angle I would prefer.
Dipper has one too very close to mine, custom geometry.
that's the best thing about nicolai, custom geometry. most of their off the shelf stuff doesn't appeal to me, but the ability to tweak it to your desired ride is a great option
They should be able to get the clearance with an ion style bb which is far tidier than the fr stub
Dipper, just quoting an email I got about my custom 29er
'Please take a look at the attached drawing. I had to move the seattube 25mm foreward (like the old AFR style).
We will include this feature into all our 29" frame for 2013 because only with this change we can realise 140mm of rear wheel travel.'
Premium Member
Taking into account I own both :)
I can't copmpare them, they are both different tools for different jobs... I am with dipper, for an all day epic ride, would take the 72 HA AC, and for play and more play, would take the longer travel 68 HA AM type...
The AFR style rear is needed due to getting the longer travel whilst keeping the reat chainstay as short as possible...
I have my doubts that the progress forward in longer travel 29ers will continue to happen. All the effort will go into the 650b platform :( Of which is more driven by bike companies, not joe public (just my opinion)
In saying that, the bike I ride most is the AM 29er.... I lifted the stancions on the fork some 20mm over the weekend, so it has slackened it a little more... Not much time on it, due to breaking spokes over a jump... Hummmmmm
Oh no, the ENVE's are not totally bullet proof :-O
Or you have it set up like mine with an angleset and compromise inherent head angle.
Mine is 69deg with a 120mm fork and almost 2lb lighter in xc trim, just switch tyres and fork (10 mins) or 67.9deg with the 140mm fork. Both with the angleset on min 0.5 slack. spin it round and you have 70deg with the 120mm. The frame is only 150g heavier than the std bike. Travel is between 120mm and 147mm at the back.
I'm running it at approx 67deg for gravity/play/jump oriented but 68 for normal.
So for me it does all of those jobs. All the kit on it is light but strong (If unfortunately fairly expensive) with no compromises, I use 1x10 for everything now. XX1 would make that even easier but unless CK bring out a new freehub, I wont change the hub for the extra on the back, just MTFU. I could lose another 1lb for xc by changing the wheels i.e using lighter hubs, but don't feel its necessary.
It runs at 28lb set up 140mm with 2.4 Ardents tyres 1x10
26.5lb with a 120mm German:A fork and 2.25 Ardents/2.0 muds [I don't have the German:A fork yet. They are awaiting the tapered steerer version in]
1 - 15 of 15 Posts
