I got the alp today and Im thrilled, it looks great and went together with almo st no problems at all. Some minor adjusting after the assembly and I was nearly ready to rock. I also took some pictures and hope to get them up here tomorrow. However, I need help, ok I need a lot of that, but were just going to narrow it down to the bike for now.
This is my first xp with disc brakes, so pls bear with me...
The front brake cable is fed from the lever through the inside of the front fork to the brake housing I noticed on the ibex website pics that it does appear this is correct, although it appears different models do feed that cable to the outside of the fork. I also dont see any kind of cable management that it may need to slide into. The issue Im having is that the cable in its current position gets stuck on the tread from the tire, and does so with so much so much zeal that it does stop the tire, and Im assuming it could also pull the cable out if I were going at it with any more umph then just pushing it around my basement. Its just an all around bad thing.
So, is there something Im missing with that cable to get it out of the tires way? Im guessing my options are to either remove the cable and feed it on the outside of the fork (easier said then done I think), or to tie wrap in some manner the cable to the fork itself to keep it out of the way.
I know I can call ibex on Monday and I dont doubt for a second that Ill get a good response, but I wanted to run it through on here first and get your thoughts. Thanks!
