The stock shock is the Fox Float CTD Performance.
I set the pressure/sag to Fox's instructions and come out about 185 psi (I'm about 200 lbs).
There is no noticeable difference between the Climb and the Trail settings on the shock. Just sitting on it or pumping it a bit in the parking lot, there's no difference. Nor do I feel any difference when riding on the trail. I can tell a difference when putting it in the Descend setting. On the fork (also Fox CTD Performance), the Climb setting nearly locks out the fork.
I never used the Climb setting on the shock much before. However, I moved and can ride to the local trail head which is only about 4 miles away via bike paths, which is how I ended up noticing that Climb and Trail were pretty much the same.
I took it in to the shop for pre-season maintenance and the mechanic said he can't really do much, that he'd have to send it in to Fox which will warranty it if there is a problem. But looking online, I can't really find a definitive answer if this is a malfunction, or if the shock is just that way. I know there are a lot of Anthem owners on here, so I figured I'd ask you. Has anyone here run into this problem? Does your shock act like this, or should I go ahead and have it sent in. Race season starts in a little over a month, so the earlier I get this sorted, the better.
Thanks for any help.
