1 - 6 of 6 Posts
Discussion Starter #1 (Edited)
Just picked up this GF Sugar 3 and I believe he swapped out the forks. I want to find the manual for them so here's where all of you come in :thumbsup:
Seems to have around 4" travel.
No adjustments for travel, rebound or lockout.
Under each top cap there is a valve to add air to the shock.
On the bottom of each leg there is only oil drain plugs, no adjusters.
Thanks for the help,
Tono
Discussion Starter #4
Thanks guys...
I'll have to get into the forks themselves to determine if they are the 2002 or 2003 models you mentioned.
I was pretty convinced that they were 2003 MX Comp Air until you brought up the 2002 models. Very similar, but with your imput I'm pretty sure I can now narrow it down.
Thanks again,
Tono
1 - 6 of 6 Posts
