The Inbred is out of commission until I can get it back to the distributor and get a replacement frame. In the meantime, someone in my local bike club here in Seattle had a Klein Adoit frame that the derailleur hanger had gotten bent. Since you can't rebend aluminum, the frame can essentially only be used as a singlespeed. Last night was its initial reborn voyage in the new configuration. Unfortunately, I wasn't able to get the rear brake internal routing to work (spent over an hour trying to thread the cable) so I finally gave up and just used full length brake housing.
I did have the chain drop off twice last night so had to do some on-trail tweaking (ie bending) of the tensioner. After that though the chain stayed on for the rest of the ride. I'll get used to the Klein the more I ride it but the initial 20 mile ride showed it to be a very capable beastie. Headset is a wee bit loose so hopefully the local Klein dealer will still have the tools to tighten the Klein headset up.
