I’m not running tubeless yet, tubes still seem to be engraved in my biking for simplicity. I am running 26x2.1 on Araya rims, and Alex DH19’s on the other bike. Both bikes are at 20 psi front, 30 rear. Discs on one, vee’s on the other.
The first concern is tire/tube slippage. Routinely I find the tire/tube has slipped so the valve stem is canted towards the front. So as not to shear it off, I deflate and readjust it to vertical. It seems to help slightly when I seat them to 60psi, then back off the pressure to the desired level. Any tricks to keep things where they’re supposed to be?
The second issue occurs only on the bike with Araya rims. Occasionally, I find the rear tire has lost pressure dramatically after a ride. Down to 10 to 15 psi. Can’t find a leak, and the tire will hold pressure indefinitely after a pump up. Weird! Any cause you can think of? Haven’t really submerged the tube to look for the leak as a quick fill seems to last. Will impact on obstacles cause this?
Thanks, folks
Thanks, folks
