I've been shaving my legs for a while now, and while at first I was using shaving lotion, the idea(s) below seem to work a little better.
I've been using Basis samples, a "cleaner clean face wash" that I got from a booth at Sea Otter this year (and am almost out of, dammit). Dump about 1/2 an ounce under running water in the tub, throw the razor in and let it soak. Hell, throw your legs in there, too, and let them soak. If you can't find Basis at your local drug emporium, just use something that will make the water a little soapy. Mr. Bubble works, but you might have to use lotion on your legs afterwards. The soap seems to irritate more than something like Basis, which rinses off cleanly.
Shave with the grain. Or against it. Or sideways, for all I care- whatever works for you. Keep rinsing your legs to keep up the invigorating sliming soapy action.
I still haven't found the perfect razor, so I got nada to recommend. I hate the razors with the "lubricating strip". They're too snotty at first, then they're ok for maybe one shave, then it's downhill from there. Right now, I'm using single-bladed Bics without a lube strip. Not quite as close a shave, but... I would advise against cheapo store-branded razors, tho. Unless you go by the credo "Chicks Dig Scars".
Any other thoughts?
fp
Any other thoughts?
fp
