1 - 14 of 14 Posts
Hey Guys,
looking to get into riding a 29incher. I will mainly want to just bomb around town hitting the bike paths and coffee shops. It will have to be a single speed as I love the simplicity. I have a Kona JTS and a Kona Unit (26incher). The obvious choice would be to get a 29incher Kona Unit. However, I would like to try a different band. I have a few vague criterias/questions:
1) I would prefer steel.
2) I want to build it up with disc brakes.
3) I want to have the option of easily changing the gearing from a town to mountain (maybe even run it as two speed). Are there any durable two speed hubs (i.e. the old Sturmey Archer types)? Or should I run two side-by-side cogs and cranks and have an EBB to take up the chain slack?
4) Would disc brakes need to have their position reset if the drive line center-to-center distance changes if I decide to go with track ends?
5) I don't have deep pockets - up to a grand for the frame and fork would be my limit.
Looking for guidence and recommendantions.
Cheers,
Mark -%)
Recovering couch patato
Welcome to the forums!
Holy smokes, a grand for a singlespeed commuter frameset!? Dude, don't show off you're loaded as much!
A grand buys you a complete On-One bike, minus the discs. Or 2 Redline Monocogs.
On the singlespeed forum many people are runing dual chainrings and cogs, together adding up to the same total toothcount, so chain lengths are similar. I think they call them dinglespeeds. Like 32-18 and 36-14 (both adding up to 50). The latter would have a higher chain tension when not adjusting chainstay length. Swapping gears is done manually. Push of at the chainring, change cog, "shift" on to the other chainring. Requires a dismount and greasy hands, though.
Redline Monocog, On-One Inbred 29er, Niner s.i.r.9, Haro, Kona, Surly, custom. Who'd I leave out?
Yes
I think easiest option is the side-by-side. http://forums.mtbr.com/showthread.php?t=167302
I don't know about track ends, but I haven't had to reset the brakes on my Inbred with sliding dropouts.
That's more than enough budget. You can get that entire Monocog bike for much less than a thou. The Inbred as a complete bike is around $1000: http://www.webcyclery.com/product.php?productid=17504&cat=23&page=1
Nat - you left out Soma, Voodoo, and soon that new Zion frame that'll be coming out from Jenson USA. Oh yeah and the Raleigh - but that seems like it will be very hard to find.
QBall frame will suit your needs just fine. Hand built steel,disc brake only, SS or gears, sweet disc setup, and a hand built fork for $530.00.
The Duuude, man...
I suppose the old KM is either too obvious to mention, or just so "old" that it's not hip anymore?
The Duuude, man...
MMcG said:
Nat has it in his list.
Dang, I still don't see it...but I haven't had any coffee yet this morning... :skep:
edit: ah, there I see it, he just said surly...whew, man, it's a wonder I make it to work in the morning...
Har! Not your fault; I can barely type in the morning.
BigWheelsKeepOnTurning...
laverda3c said:
Hey Guys,
Cheers,
Mark -%)
Call Rob at Badger Cycle....you can't go wrong. :thumbsup:
1 - 14 of 14 Posts
