So after running a set of Titec Hellbents for the last 5 years I decided that it was time to replace them. I have been experimenting with stem lengths for awhile to get my Bullit fully dialed. I finally have settled upon a stem length so I decided that instead of running the el-cheapo supergo stem with the old Titec I would make the jump to new gear.
First on my list was a Truvativ 31.8 xc/fr bar.
Specs:
Cold drawn butted AL-66
5 degree backsweep
580mm width
31.8mm clamp diameter
Blast black finish
169g
It is lighter and wider than my Titec. Comes stock on the kona XC/light FR bikes. The 31.8 clamp area looks gi-normous and a little ugly because this is not a top end bar so the swagging is a little cobbly.
Second was a suitable stem with a little bling potential
Raceface Diabolous 31.8 50mm stem
Specs:
RISE: 10 Degrees WEIGHT:250grams(50mm)
BAR DIAMETER: 31.8
COLOURS: Bad Ass Black
WARRANTY: Lifetime
Very portly but really very attractive and stiff beyond all get out.
Review:
This combination is so stiff that I can't believe the increase in precision in my bikes ability to pick a line and hold it, and I have a fairly stiff set up with a 20mm through axle up front and a triple compatible SC Bullit frame with very stout wheels.
After my first 4hr epic aboard this new set up I found that my triceps are sore as are my shoulders but the prerequiste blisters on the callouses of my hands were absent. I suspect that the stiffness made my arms sore because I was working the bike because I could now be more precise and I suspect that the blisters were absent because the effort to maneuver the bike (eg bunny hop, manuals, climbing etc.) was less due to the stiffness
Decision:
I highly recommend this upgade for anyone that is looking for an increase in stiffness and durability plus the added perk of increase precision in steering/drops that it affords. i believe that this will eventually become the standard in mountain bike stem/bar interfaces.
This set-up seems to be the perfect upgrade for those that run a 6"+ travel single crown Freeride set up( or obviously DH setups). I would avoid this on any rigid bike though because, again as if I didn't stress this enough, this set up is stiff with a capital S.
Specs:
5 degree backsweep
580mm width
Blast black finish
169g
Specs:
BAR DIAMETER: 31.8
WARRANTY: Lifetime
Review:
Decision:
