If you're pushing that bike hard enough that a thru axle actually matters over QR, the rest of it will not hold up all that long. Best to just wait till it's bike upgrade time IMO.
i get that but is there any temporary options such as just a nice strong QR or 9x100 thru axleIf you're pushing that bike hard enough that a thru axle actually matters over QR, the rest of it will not hold up all that long. Best to just wait till it's bike upgrade time IMO.
Thru-BOLTS will work. Not thru-axles. They require different dropouts on the frame.You can run a 135x10mm through axle in any 135 QR frame. You'll need a 135x10mm through hub and the axle. It's unlikely your current hub is convertible so you're looking at a new hub and rebuild or shop used. You might score a smoking deal on a 135x10 built rear wheel. As for the fork, you're stuck with QR.
As for your frame being135x10 or 135x9. All 135 frames that use a QR are 135x9 but they will all take a 10mm through axle.
DT makes both RWS 5mm skewers AND 9/10mm RWS thru-bolts. The skewers would be a drop-in improvement but would be a small one. Probably as good as shimano skewers, but different. thru-bolts would be a little bit larger improvement, but probably would require new wheels.DT Swiss RWS Skewers if you wheels will take it.
Otherwise a Shimano QR skewer generally has the strongest/best clamping interface.
You can run a 10mm through axle on any 135mm frame. It was something a lot of riders did before 142. The through axle attaches via a nut rather than threading into the frames dropouts. I still have a 10mm through axle made by Trek that I ran on a few different 135x9 frames before 142 took over. All you need is the axle, and a hub that will accept it.Thru-BOLTS will work. Not thru-axles. They require different dropouts on the frame.
The axle specification for regular front QR is 9x100, and for rear qr it is 10x135. These use a hollow axle with a 5mm QR. To change to a thru-bolt, you need hubs that can accommodate a 9mm thru bolt for the front and a 10mm thru bolt for the rear. DT Swiss RWS thru bolt is probably the best widely available example of this.
Anyone that says the rear is 9x135 is mislabeling the rear axle spec. Lots of manufacturers do this. Lots of riders do this.
that is not a thru-axle. that is a thru-bolt.You can run a 10mm through axle on any 135mm frame. It was something a lot of riders did before 142. The through axle attaches via a nut rather than threading into the frames dropouts. I still have a 10mm through axle made by Trek that I ran on a few different 135x9 frames before 142 took over. All you need is the axle, and a hub that will accept it.
I see what you're saying but people called them through axles because the 135x10mm hubs were called through axle hubs.that is not a thru-axle. that is a thru-bolt.
a thru-axle requires closed dropouts on the frame, whereas a thru-bolt can fit into open dropouts.
The language was sloppy AF then and it is sloppy AF now. on the hub side, the distinction doesn't matter as much (nowadays, the hubs that will fit a thru-bolt are the same ones that fit a thru-axle and a QR, just with different endcaps).I see what you're saying but people called them through axles because the 135x10mm hubs were called through axle hubs.
