1 - 8 of 8 Posts
FYI: I just purchased a Specialized Stout front hub with their Skraxle thingy on eBay...predecessor to the RWS system that DT-Swiss uses. I'm hoping to stiffen up my fork/hub connection and this option is cheaper than a DT-Swiss set-up.
Sellers Name: otherwisehk
I don't know if they have more, but they've posted a couple in the last week or so.
$58 shipped from Hong Kong.
Just thought you might like to know.
Disclaimer: I've got no connection to the seller, just interested in the system.
Banned
only $4.00 cheaper than the dt swiss.
I would go for the dt swiss from chainreaction. You know what you are getting with dt swiss.
http://www.chainreactioncycles.com/Models.aspx?ModelID=21670
These hubs are fine. I bought one a couple of years back when cambria was blowing them out for $18. They use non-adjustable but good quality sealed bearings, and the thru-bolt adds a lot of stiffness over regular qr's. When the bearings get notchy, you can just tap them out and replace them.
I stopped by the Hadley shop and picked up a bolt-on aluminum thru-bolt for mine--much lighter than the steel skraxle and allows for very high clamping force.
Discussion Starter · #6 ·
Yeah, got the hub too.
I had a non-disc Stout hub that came on my '97 Stumpjumper. I remember it being a really smooth roller, I just didn't like the Skraxle. It was hard to open from time to time. If I have the same experience this time, I'll pick up the DT-Swiss skewer or look into that Hadley option.
Hey Guys,
Don't mean to take this off topic but is a DT Swiss axle, skraxle or whatever you call them more stiff than an ISO hub up front with a standard skewer?
I just had a wheelset built up with an ISO CK hub and didn't realize I can't use the DT Swiss axle thingy.
err, 27.5+
Gonna hate me for posting this, but here goes...
X-post clip from best deals forum:
"Nice, was able to pick up a 9mm thru axle front hub for $16 shipped using the "HOTDEAL20" code. Thanks
Specialized Stout hub if anyone else is looking for one
http://www.cambriabike.com/shopexd.a...FRONT+DISC+HUB
Only negative is that it uses the DT stlye spoking (way different length on the spokes and different tension)"
1 - 8 of 8 Posts
