What is the difference between a 9mm Open QR or QR15 Thru axle system?
I am thinking of ordering this fork for my 2011 Kona Unit, but don't know which model to order.
Fox 32 F29 100 Forks 2011
Specifically designed for 29er platform
Weight (including axle): 3.92lb/ 1.78kg
Travel: 3.9 Inches/ 100mm
Adjustments
RLC - Low-speed Compression, Lever actuated lockout, Lockout Force adjust, Air Spring pressure, Rebound
Damper: FIT
Stanchions: NEW Kashima coat
74mm Post style disc brake mounting
Steerer: 1 1/8 or 1.5 Taper
Spring: Air
Color: White
Intended use: XC
Adjustments
Damper: FIT
Spring: Air
Color: White
Intended use: XC
