Generally I'm coming around to 20mm axles...or 15mm...or 24mm...or 25mm...for nearly everything. But I've started to think that bigger wheels may benefit the most from stouter axle interfaces. If you think about it, the bigger the tire/wheel is, the bigger the leverage it has while it works its magic. It's probably even more of an issue on a 29'er.
No...not every bike or rider needs a huge axle. The harder you ride, the more technical terrain you ride, and the more discriminating you are in suspension feedback, the more you'll appreciate a larger front axle.
