I read through many posts on Judy, but the thing is, I'm not sure the exact model of my Judy… Can someone definitively tell what model this is? I believe 1999 Judy Race (no XL or SL or any suffix) with Hydracoil, 80mm travel, practically for free for my hard tail designed around 63mm fork (not too many options as you know).
Does anyone have a service manual for this one, or a link to one? I have a PDF 99 manual for XL/SL but something looks different. For example, it has single springs (not a stack) in both legs with bottom attachment (spacer?), where the manual says 2 stacked together (SL) or one with a spacer right below the pre-load body (XL). Also, I don't think this one has a dual adjuster. I can't tell what this "Adjuster +/-" does to be honest. The XL/SL manual says to pull up and adjust the compression - mmm, I don't think I can feel that.
In short of a manual, can someone tell me how much fork oil I'm supposed to put in from the bottom of the legs? XL/SL manual says 10cc, but a 01 Judy instruction in Enduro Fork Seals web site says 150cc, that's a lot more. Thanks in advance.
Alternatively, is 2002 Manitou Black Elite 80mm (TPC with grease port, compression, rebound adjustments, no bath) better than this Judy for XC riding for 160lb rider?
