When I put a 130mm Z1 on a DBR X Link years ago I had that wheelie problem at first up steep climbs, just took short time to get used to it by changing your body position more forward and using different muscles. I have no problems at all when I ride it now.
When you add" 20mm" spacers(never done this,youd have to make them out of metal or plastic or buy something at the hardware store to work and fit,easy enough thou) to existing bottom springs or use longer bottom springs the fork is being restricted how much it extends back up.thus your top springs won't have the same room as before forcing you to push(preload them,stiffer)to screw in the top caps. I've only modded 80mm. Z2 marzocchi forks to get a little more travel, but with old Z1's Marz sold the spring kits for 100(longer bottom springs,shorter top springs) or 130 travel(shorter bottom springs,longer top springs) Hope this helps.
Edit you may have to change your saddle's nose angle back down a bit if you lengthen the front fork.
