98 As-3
1034 Views 3 Replies 2 Participants Last post by  SiberianYETI
I am an old roadie exploring off-road. Just bought a new (out of the box) 98 AS-3 frame and building it out. Requested specs from Yeti ... no luck yet. Need to know the recommended front fork travel for this frame - 80mm, 100, 110, ??? Does anyone own one of these?
Need all the help I can get.
Patching it together!
1 - 4 of 4 Posts
I can't give you the "recommended" travel...but I have what I believe is a '02 Manitou Six Deluxe on a YETI AS3 frame ('98). You can see it below. Overall I have no complaints, but I've only been riding it for about a year and have nothing to compare it to. I believe it is 80mm. I'm just getting ready to sell this frame, as the shock has been blown and is expensive to replace (and hard to find). Many hard miles put on it though and no complaints otherwise. :)
Larger size - Large Pic
That is a sweet looking machine! :) Let me know if you have any luck with finding a replacement shock ... seems to be a common complaint so finding a replacement (spare) early seems like a good idea. I came across 2 bike builds on Epinions.com with forks in the 80 -100mm range. What size is your frame (in case a buddy might be interested)?
Appreciate the info and your candor!
I had to call Yeti direct to get the right shock for this particular frame (if I wanted to replace it). It still rides OK (I've ridden it with the blown shock all season!) because the spring around it is pretty stiff. However, I notice it most due to the resulting pedal bob and my rear travel is also likewise restricted.
If the shock hadn't blown I'd have ridden this frame until it fell apart.
I bought this frame off a buddy of mine, and he thinks the frame is a 17". It fits me at 5'8" and about a 30" inseam. I can't find any markings which would tell me the factory specs...
The only other issue this particular frame has is the rear chain-side part of the frame is ever so slightly bent inward towards the cassette, just enough so I cannot use my highest gear on the cassette. This happened when I crashed and fell on top of my rear wheel, landing on the still rotating brake rotor so it sliced through my knee (ouch!). The weight of me must have tweaked it over maybe 1 or 2mm. I have been hesitant to bend it back lest it weaken the welds somewhere. I only ever notice it on pavement when my buddies hit that extra gear and I cannot...or when they are in their big chainring and I am only in my middle (I run with a bash guard instead of a big ring). :D
1 - 4 of 4 Posts
