1 - 4 of 4 Posts
I'm just about to change my chains and I'm wondering if I am going to have problems if I use a 9 spd chain instead of 8 spd. I have a 9 speed front derailleur and I get a bit of chain rub using an 8 speed chain.
I've read that 9spd chain is ok on the 8 spd cassette but not sure about 8 spd cranks.
Derailleurless
Shimano recommends against it, but I've had no trouble in the past running a 9 speed chain on 7 speed chainrings, which should be identical to 8. I think they're worried about the slightly narrower chain getting jammed inbetween rings, but if you've got chain pickup ramps I imagine this wouldn't be a problem as it might be on non-ramped rings.
9 spped chain on 8 speed
I've run a 9 speed chain on my 8 speed system for 2 years now. Race Face 8/9 speed on front, XTR 8 speed rear cassette. When I was in local bike shop recently I mentioned this and I thought I was going to have to dial 911 as the
computer glitch...
the local bike tech almost had apoplexy. Talked about all the horrible things that were going to happen to me. I figured they would have happened by now. Shifts fine, XTR cassette looks good after 2 years. Replace the chain if it stretches 1/16-1/8 inches. I listen to these bike guys and decided a long time ago that they don't know much more than me.
1 - 4 of 4 Posts
