1 - 5 of 5 Posts
Certified Bike Junkie
I was just geting around to setting these up on a bike but the place on the lever where the ferrule fits is 8mm which is much large than the cable. Is there some kind of spacer that I can use or were the cable housings actually that big? If so, what are my options?
Dumpster Diver
You have a pm.
BIG cables
Any source for the larger cable, housing and ferrels?
I've got the same Suntour set up going on the '94 Kona project...
Back in '88 I used large cables for most my setups.
Also- What ever happened to the Dia-Comp cables that were rolled smooth?
Seems they are no longer available and a simple way to reduce friction rather than coating the cable as is now so common.
1 - 5 of 5 Posts
