1 - 2 of 2 Posts
Just buy a set of non-UST Maxxis High Roller 2.35 SuperTracky tire, wire bead.
I am using the Mavic 819 UST rim, so I put some Stans into the tire and mounted it on without tubes.
I have never tried to use a wire bead non-UST tire with Stans before, should I be worry about anything??
Nope, shouldn't be a problem...
keep in mind that the bead on a non ust tire is not the same as a UST specific tire and is more prone to slipping off the rim and burping air. The wire bead will help in that respect, but it still isn't the same. Just keep your air pressures reasonable and you should be fine.
Good Dirt
1 - 2 of 2 Posts
