Hey all,
I’ve just gotten a dual air fork reduced from 5 to 3” of travel. I’ve heard from everybody I’ve talked to and read in every forum that the suggested psi in the RS manual was too high but I find it way too low. I setup the psi in both the pos and neg travel according to the manual and it felt way too soft, I was using 80% of travel just on stand over. Took it off a couple 2 footers and it did not bottom but... I bumped it up 20 psi higher then what they said and still I use up 50% of travel just standing on the bike. Even when I was running the fork at 5” I had it higher. The big downfall with having it higher is that it kicks back/ does not handle small bumps very well. If I put the comp knob to 3/4 and the gate closed it feels ok on stand over but I don't get to use the "whole" 3" of travel...
Is the sug psi with gear (helmet/ bag) on?
What I’m wondering here is whether the fork will bottom at the suggested psi or if once I hit the trails it will be ok. Also could I run it at the suggested psi and play with the compression / rebound to get it to not to use all the travel on small bumps?
thanks
thanks
