1 - 7 of 7 Posts
bi-winning
My 80mm fork has barely any sap at all. <5mm. It's not a super plush fork. The only adjustment is air pressure, and I don't like a fork that dives too much under braking.
Manuals do tell what recommended sag is, but it's quite wide limit. For my Manitou R7 it's something between 12 and 16mm. Next to that, when I set my air pressure so, that sag was somewhere in these limits, I was getting out something like 50-55mm of travel (air pressure was around 130psi). After that I started to experiment a bit, and lowered pressure to 110-115psi and all of a sudden I'm getting around 75mm of travel. But I just don't care anymore if sag is really between 12 and 16mm, or if it's a bit more. Fork works much better when set this way, as it did before, when it was set "by the rule" :)
PS: Pressure calculated out of riders weight (I forgot formula) is even more off. For me it should be somewhere around 140-145psi, and it felt like I would be riding rigid fork :)
1 - 7 of 7 Posts
