1 - 1 of 1 Posts
I just recently switched my Axel Comp from 80->100mm travel, but now it sounds noisy, like there isn't enough oil in the leg. I took it apart and measured the depth per Manitou spec (11-12cm deep) and the level was fine, but it still sounds like there isn't enough. Is it possible that the specs (11-12cm) apply only to the 80mm travel and that I'd have to add 2cm more of oil in the damping leg to account for 100mm?
1 - 1 of 1 Posts
