Yeah, I'm running a SRAM chain too. It's been broken around 15 times--I just keep replacing links. I tried to put a new chain on my bike, but it kept skipping because the chainrings and cassette are soo worn--this current chain is the only one that will work and it's definitely seen better days!Oliver said:My vote is for 8 speed, it stays in tune longers and the chains are stronger to boot. I also like Sram chains over Shimano. They seem to hold up better.
That could be why they keep breaking. Have you tried to replace the cassette and chain at the same time? As for Chains, make sure to get PC 971 or higher. I have seen several articles in Mountain bike action magazine about de-evolution of the drivetrain. Switching form 9 back to 8 for all of these reasons.Primus said:Yeah, I'm running a SRAM chain too. It's been broken around 15 times--I just keep replacing links. I tried to put a new chain on my bike, but it kept skipping because the chainrings and cassette are soo worn--this current chain is the only one that will work and it's definitely seen better days!
Ok, that's one vote for 8-speed, any others?
(I'm typing this for the second time, something glitched)Oliver said:That could be why they keep breaking. Have you tried to replace the cassette and chain at the same time? As for Chains, make sure to get PC 971 or higher. I have seen several articles in Mountain bike action magazine about de-evolution of the drivetrain. Switching form 9 back to 8 for all of these reasons.
Had issues with breaking chains until I got a Wipperman Connex 1x9.EastCoastHucker said:I'd say 9 and go single rin in the front.
oh... if chain is your problem and already try the Sram PC99 go for a Wippermann chain.
8 speed and 9 speed cover the same range, so your old derailleurs will work. Since they put one more gear in the same amount of space, they have to make everything thinner, which is why 9 speed chains are more vulnerable.Primus said:Time to replace shifters and drivetrain. Considering "upgrading" to 8-speed cassette from a 9-speed. I've broken so many 9-speed chains over the years that I can't help but wonder if switching to a wider 8-speed chain would be beneficial. Plus, derailleur adjustment isn't as touchy with 8-speeds instead of 9.
Here's my particular plan:
**Front shifter--grip shift (something low profile). I'm currently running a double up front with an LX derailleur. I'm debating the switch to grip shift too.
**Rear shifter--possibly SRAM "rapidfire" (or what ever there tradename equivalent is). I'm currently running a 9-speed LX shifter.
Get new cassette, chain, and chainrings. I already have new XT front and rear derailleurs.
Any input?
That's my concern. But is this really an issue? Everybody I know that rides grip shift says that it very rarely happens. I know that I don't like to have the shifter part of the grip a lot bigger than the rest of the grip. All I would need to find is a low profile grip, but the shorty version, i.e., not the one that takes half the grip length.Sudo said:grip shift suck. a bike at the LBS had some, i tried to pull up over a large curb and shifted. you really have to keep your hands right on the edge of the grips.
It may sound crazy, but how about a trigger shifter for the rear, and a gripshift for the front. That way you can trim the front if you are runnig a large amount of cross chain.Primus said:That's my concern. But is this really an issue? Everybody I know that rides grip shift says that it very rarely happens. I know that I don't like to have the shifter part of the grip a lot bigger than the rest of the grip. All I would need to find is a low profile grip, but the shorty version, i.e., not the one that takes half the grip length.
Actually quite a few people run their rigs this way. I used to do that with my Norco.Oliver said:It may sound crazy, but how about a trigger shifter for the rear, and a gripshift for the front. That way you can trim the front if you are runnig a large amount of cross chain.
This is exactly what I was saying I was going to do. All I need to know now is what shifters I should get. I want a grip shift for the front and I want a trigger-type shifter for the rear. Anyone got any beta on SRAM's trigger shifters?Oliver said:It may sound crazy, but how about a trigger shifter for the rear, and a gripshift for the front. That way you can trim the front if you are runnig a large amount of cross chain.
the best on the market....run an X9 before you run an X 0Primus said:This is exactly what I was saying I was going to do. All I need to know now is what shifters I should get. I want a grip shift for the front and I want a trigger-type shifter for the rear. Anyone got any beta on SRAM's trigger shifters?
Sorry, been out of the bike biz since '02, so enlighten me by elaborating what X9 or X0 is/are.SHIVER ME TIMBERS said:the best on the market....run an X9 before you run an X 0
