1 - 6 of 6 Posts
Is it possible to install an 8 speed cassette on a 7 speed hub (if for eg remove one coq) so it can work with 8 speed pods? Thanks
It should work. Spacing on Shimano is 5mm for 7 sp and 4.8mm on 8 sp. You'll wind up with a phantom gear but everything should work. Good idea, let us know how it works.
Mmm... Tasty
Don't think anyone is going to care about this reply, but the answer is "you betcha". The freehub body is narrower on a 7sp hub than an 8sp hub (and remained unchanged for 9 and i presume 10sp). Advantage of 7sp hub is less dish on the wheel = stronger wheel. Practically speaking, though, that isn't a huge deal.
Can you run an 8sp cassette on a 7sp body? Sure, just drop off the small cog, add a thin spacer on the back of the cassette to take up the resulting very slight free play (may or may not need that depending on the cassette you use - my experience is with taking the 11t cog off an 11-28 8sp XT cassette). 7sp and 8sp shifters are effectively interchangeable.
Does Shimano use pins or screws to attach cassettes these days? My older 7 sp cassettes all have screws.
Best option is Eight of nine on seven from Sheldon Brown;
"Any 7-speed Shimano Hyperglide Freehub will actually work with 8 or 9 sprockets, without any modification! What you need to do is to use 8 of the sprockets from a 9-speed cassette, with the 9-speed spacers -- or 9 of the sprockets from a 10-speed cassette.
To make this work, you'll also need to use a 9- or 10-speed chain and shifters. Your old 7-speed derailer (except 1996 or earlier Dura-Ace) should work OK if it isn't too badly worn. Most, but not all, 9- and 10-speed shifters will work.
The limit stops on the derailer will cause the useless position on the shifter to be locked out, so this will work as a perfectly normal 8- or 9-speed rig."
RIP Sheldon!
RIP Sheldon!
I've seen that but never tried it. Have you actually tried it? You could use 8 sp barcons which plentiful and cheap. Neither of which 7 sp barcons are.
1 - 6 of 6 Posts
