I can't remember....
Can you run 8" rotor on back of motolite ?~?
8" rotor on front and back.TiEndo said:What are you planning??????
I'm on 185's already....TiEndo said:You just love that bigger is better feeling don't ya........, think eight is cutting it close, FM may be the only one to answer that..........why not 185 in the back?????(7")
I was heating up the rear and just as smelly as the front. That was on the Avid BBDS's but I destroyed a caliper last weekend on a descent. The proposed set is 8" Hayes front and back because someone local removed then off his new bike. I would get a bonzer deal.TiEndo said:And you're not locking up the rear at all??????........Could always just do the front first and see how that goes.......(you're just getting ready to switch to a SuMo![]()
Should be no problem. Demoslug runs a big rotor in back... when they fit it generaly means you can. :thumbsup:All Mountain said:I was heating up the rear and just as smelly as the front. That was on the Avid BBDS's but I destroyed a caliper last weekend on a descent. The proposed set is 8" Hayes front and back because someone local removed then off his new bike. I would get a bonzer deal.
If its a good deal then go for it......Hayes are pretty grippy(ie on off feeling) so get it and switch to a 185 if you feel its too much.......but just for the front is worth it if someone's giving you a bonzer deal.........All Mountain said:I was heating up the rear and just as smelly as the front. That was on the Avid BBDS's but I destroyed a caliper last weekend on a descent. The proposed set is 8" Hayes front and back because someone local removed then off his new bike. I would get a bonzer deal.
Do it !~!~?~? Brother, I almost pulled the trigger on a 66 SL ATA yesterday slightly used. Thankfully I came to my senses today when I asked why it was being sold. He said it was too much fork for his trail bike. After little thought, I politely told him 'same scenario', but no thanks anyways. I can do some stupid things sometimes....blackagness said:Should be no problem. Demoslug runs a big rotor in back... when they fit it generaly means you can. :thumbsup:
Thats cool. Are you 8" in front? That would definitely help! As for me, I am running 4-pot shimanos which make pretty much any size rotor feel big. Go for it, why not!All Mountain said:Ta FM.
6" rotors on the back don't cut it in the steeps at my weight. With a 7" rotor I was still heating it up to the point of almost too hot once every couple of runs.
Thanks SLOclyde :thumbsup:.... from one clyde to another (220 lbs).SLOclyde said:I run Hope Mono M6's with 203mm rotors front and rear. I do this because I'm over 240 lbs. No problems that I can see on the Motolite. The rear disk is very close to the chain stay, but I've never seen it rub or anything.
Some people have said that large rear rotors are harder to modulate, but the Hope's modulate very well.
10-4...that's why I only ride Hopes. I ride an M4 200mm rear on the FXR....I find I can really modulate the braking force with the larger rotor. I guess folks think it's harder cause ya got more brake. But I find the opposite. Ya got so much brake so you can apply just the force ya want. But maybe that's a Hope thing.SLOclyde said:Some people have said that large rear rotors are harder to modulate, but the Hope's modulate very well.
But dragging damages the trail... personally I brake more with my front and never drag any of the brakes unless I am crashing or something jumps in my path...Dropin%Dug said:I do a lot of trail or drag braking rather than crunching the front. Only really use the front when the going gets fast and furious and even then it's in small doses. Best not to get too friendly with the front brake in my book. :eekster:
Thanks Demo. Like looking in mirror (except the formula's).demo_slug said:yeah, I got the FR lowers on my motolite just to run an 8'' rear disk. PS. you have to have the FR lowers. does not fit with the 2005 lowers. also, depending on the weld on the chainstay, you may have to file the weld down to get some clearance. but its the same deal for the supermoto. and depends on your hub. ( and I suspect may not fit on ML2's new chain stay) also, I accept that the 8 inchers may lead to the seat stay to fail someday.
the ML braking is not as active as the supermoto, the lock up is still very predictable. and I never had any modulation "issues" even with hayes 8''.
I run the 8s for the added heat capacity. but that really was more of an issue with avids and hayes. sqeaul, fade n boil. and I can honestly say that I toasted them every ride. it was so bad that I realy had to focus on not cooking them. It used to be a big victory fo me to get to the bottom of "braille" with functional brakes.
but that was until I got my formula oros..... they work.
