I'm a newbie with 2006 7point7 and have several suspension set-up questions.
Marzoccchi 66 RC2X Questions.
1. Is air used to set pre-load or spring weight (currently 0 PSI)?
2. How is Sag set (air/oil/spring/combination)?
3. Given the above, what air/spring settings should I use for my weight at 190lbs.
4. What settings have others of my weight found to work (Free Riding w/6' max drops and want a stable (responsive) ride at speeds up to 20mph in hardpack (Idaho) conditions.
FOX DHX 5.0 Coil
1. Current spring is a 300lb and seems to soft? What is the correct spring weight for me?
2. What is the air settings used for (assume spring is used to set Sag)?
3. What settings have others om my weight found to work (Free Riding w/6' max drops and want a stable (responsive) ride at up to 20mph in hardpack (Idaho) conditions.
Any other items regarding bike set-up would be greatly appreciated as I'm not sure what additional questions should be asked.
Thank you in advance.:thumbsup:
FOX DHX 5.0 Coil
